-   -   mfi micro switch (http://forums.pelicanparts.com/porsche-911-technical-forum/367674-mfi-micro-switch.html)
chan1408 09-18-2007 10:55 AM
mfi micro switch
under the throttle lever - shut off fuel on over-run. Anyone know if these are still available? I couldn't find them on PP or Stoddards. Any help appreciated
Thx
304065 09-18-2007 11:08 AM
Search and ye shall find.
http://forums.pelicanparts.com/porsche-911-technical-forum/8039-help-please-70-2-2l-engine.html?perpage=20
chan1408 09-19-2007 07:12 AM
thx John!
Chip
Early_S_Man 09-23-2007 11:54 PM
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&co mmand=DWsearch&description=901.613.106.00+&I1.x=11 &I1.y=5&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE= ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FI LTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON&FILTER_ APOR=ON&FILTER_PORS=ON&FILTER_911E=ON&FILTER_911M= ON&FILTER_911L=ON&FILTER_996M=ON&FILTER_356M=ON&FI LTER_9144=ON&FILTER_944M=ON&FILTER_928M=ON
The type of standard, extended-length over-travel plunger I suggested as a replacement for the MFI microswitch is quite common, and can sometimes be found at local HVAC supply stores, however, it must be mounted slightly lower, requiring a minor modification [extension] to the existing bracket that is entirely reversible.
There are still some problems with the online version of Allied's catalog regarding images of individual items, but I finally figured out that they do sell a sealed microswitch quite close to what is needed for the MFI switch! Part # 642-2120 is currently$26+ from Allied, and replacement seals are available, too
http://www.alliedelec.com/catalog/pf.asp?FN=970.pdf
http://www.alliedelec.com/Images/Products/Datasheets/BM/HONEYWELL_MICROSWITCH/Honeywell--Microswitch_Industrial-Control_6421076.pdf
http://forums.pelicanparts.com/uploa...1190617092.jpg
zzwhm 09-24-2007 06:02 AM
I was able to order the original Porsche microswitch from a local shop here in Ft Worth. Part #90161310600. It was $131 with shipping. I have an extra new one if anyone needs it.
Bill
