Cabriolet dead pedals?
Any suggestions for a dead pedal that will fit on a Cabriolet?
87 911 Carmine Red -- Recaro Pole Positions, Schroth 6pt, DAS roll bar, Rennline Strut Brace, Bilsteins, Borsch cat bypass, Fabspeed airbox, MaxHP Multiboard. MidOhio, Gingerman, Putnam. |
Rennline
Check out the Rennline deadpedal. I have one in my Targa. Fits the odd wheel well spot perfectly and did wonders for providing a good foot position for long drives.
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_INTacc_pg10.htm#item9 Good luck, Gordo
Don "Gordo" Gordon '83 911SC Targa |
Installed
Picture installed
Thanks Gordo, that's what I was looking for.
I'm in the process of putting wood blocks on my pedals so I can slide my seat back. I'm only 5'3" and right now I feel like I'm sitting underneath the windshield instead of behind it. I plan to cover the wood with metal pedals. So the Rennline dead pedal will fit right in. Shannon
87 911 Carmine Red -- Recaro Pole Positions, Schroth 6pt, DAS roll bar, Rennline Strut Brace, Bilsteins, Borsch cat bypass, Fabspeed airbox, MaxHP Multiboard. MidOhio, Gingerman, Putnam. Last edited by 911vet; 09-19-2007 at 11:55 AM.. |
I got a pelican parts dead pedal and it looks great. it took a tiny bit of cutting with a dremel tool but it fits really nice.
Great opportunity to support the forum host...... ; ![]()
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
REnnline, but you got to trim it a bit to fit in a couple areas. Somereason, cabs a bit different.
The cabs have extra metal re-inforcement in that area to increase body rigidity.
Be careful when drilling the screws for the dead pedal - there's a big wiring harness for the computer right behind the carpet there that can blow out your computer if you don't move the wires over - don't ask me how I know.
Wow, thanks for the alert. I was not aware of that. I can guess how you know.
