rnln's Avatar
question on valve cover gasket.
I replace the valve cover gasket maybe a month or two ago when I adjusted the valves. I think I didn't do a good job therefore I can hear the valve noice again. If I take it out again to readjust them now, do you guys think I can reuse the gasket or I might have to replace it?
My second question is if you guys prefer the normal kit (10-0906-091-M260) or the with Silicone Bead on lower Gasket set (10-0906-092-M260)? What is the advantage of one over another?
Thanks in advance.
Fat butt 911, 1987
Old 09-20-2007, 04:56 PM
Used Up User
imcarthur's Avatar
I went through it too for the same reason. The gasket isn't the problem, it's the nuts that leak.
Twice is OK as long as you haven't damaged them thru over-torquing. The 3rd time you can expect some dribbling, but mine stopped over the winter sleep & has been fine since. I did the racer2.7 backside method the 3rd time . . .
Ian
'87 Carrera Cab
Old 09-20-2007, 05:23 PM
VFR750's Avatar
I used the silvery gaskets and the gaskets sold by Pelican Parts. Both have worked fine.
Since you have driven the car the gasket has been heat cycled and probably taken a set. So I'd replace them.
Plus the nylon lock feature has been used, so they should be replaced.
Conservative? Yes. But an oil leak there could be bad news. Change them out, and don't worry about them.
But you first problem: valve noise. If you hear them clicking, then you do need to take care of that. Although that just means the gap between the rocker and the valve stem is too large.
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 09-20-2007, 05:26 PM
rnln's Avatar
Thanks ian,
look like I need a set anyway since I need the nuts. Which type did you get? The normal or the one with silicone bead?
Again, Thanks.
Fat butt 911, 1987
Old 09-20-2007, 05:27 PM
Used Up User
imcarthur's Avatar
Just the normal one.
Ian
'87 Carrera Cab
Old 09-20-2007, 05:35 PM
efhughes3's Avatar
Go with the silicone beaded gaskets, they are only a few $ more, and give a bit better seal.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 09-20-2007, 06:38 PM
AutoBahned
RWebb's Avatar
new nylon lined nuts should not leak
Old 09-20-2007, 09:34 PM
Jeff Alton's Avatar
Gaskets make the seal, nuts do not.
Cheers
www.turn3autosport.com
Old 09-20-2007, 09:38 PM
rnln's Avatar
thanks guys
Fat butt 911, 1987
Old 09-21-2007, 11:32 AM
dshepp806's Avatar
Yes,..leaks? Not nuts....gasket (or VC trueness)....can't blame those poor VC nylocks (funny?)
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-21-2007, 02:47 PM
