schoward's Avatar
Adjusting SC/CIS Idle
Recently had my mixture reset and timing checked on my SC. My wrench reset my idle slightly lower than I prefer (around 800), especially since I use my A/C.
Can I bump up my idle back to 950-1000 using the big idle speed screw without messing up my mixture etc? or does it all have to be set in tandem?
Thanks in advance.
Old 10-21-2007, 03:39 PM
Oh Haha's Avatar
It should be around 950RPM. No harm in adjusting the screw. It shouldn't take much turning to get to the RPM you want.
Pacific Blue
Wayne
Old 10-21-2007, 03:45 PM
Designer King
Paulporsche's Avatar
Counterclockwise to raise it.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-21-2007, 07:08 PM
