Oliver Klosov's Avatar
H-1 headlamp adjustments
I know I have seen this information posted before, but my searches turned up nothing. It may have been imbedded in an old H-4 thread, but I have searched there too. Someone had a diagram of which screws adjust up and down, right and left for both hligh and low beams. Does anyone remember this? Or, can anyone provide this info...again? I want to see further down that country lane... Thanks in advance.
'79 911SC Coupe
We may be lost, but at least we're making good time...
Old 09-17-2007, 02:58 PM
Zeke's Avatar
The identification of what each screw does should be pretty much right on the lens next to each screw head. I they haven't been done in a while, I'd take the lights out and lube the threads and make sure the long flex shaft is in its holder, etc. Otherwise, you're just gonna booger up the screw heads and maybe mess something else up.
When you've got the lights on the bench, take look and make a map for yourself.
Old 09-17-2007, 03:36 PM
AutoBahned
RWebb's Avatar
I popped up the thread I had posted on -- if your search was something other than the terms I added, please post your search terms on that thread.
again if you remove them add zip ties to hold them in if the screws fail -- they are worth $1,000 if in even decent shape
Old 09-17-2007, 04:09 PM
buttjoint's Avatar
Looking at the light, The A upper right is low beam up-down. The F upper left is high beam up-down. F lower right is high beam right left. The A lower left if low beam right left. Simple Ha ha
Old 09-17-2007, 04:35 PM
H-1 adjustments
Thank you so much for the beta. Last night I just missed a gummy moose and swerved around an endangered black footed corn mule. Those H-1s, when properly adjusted, are just sensational...
'79 911SC Coupe
Old 09-25-2007, 09:19 PM
