-   -   I cant believe I did this! Need Guru help (http://forums.pelicanparts.com/porsche-911-technical-forum/368421-i-cant-believe-i-did-need-guru-help.html)
Early_S_Man 10-13-2007 06:14 PM
Dirt,
Yes, your symptoms match exactly what a failed alarm system module does ... cuts power when the ignition switch returns to the 'run' position!!!
Dirt Nap 10-13-2007 06:30 PM
Does anyone know if the wire from 86 on the relay goes straight to the factory alarm?
If so I will check at the pull everything out so I can get to the factory alarm and check to see if I have power on that wire between the alarm and pin 86 of the dme relay.
Dirt Nap 10-13-2007 09:53 PM
I think am geeing closer to having run again!!---
Can any one tell me where the alarm is mounted on the 87 911? I removed a black box (3.5x1.75 inchs) Sachs 618.113.00 on the passenger side fender wall not the firewall beside the duct work. It has a 11 pin connector and does not look like the box in the picture in the above link.
Can anyone point me in the correct direction I think I am getting close to fixing this electrical problem?
Does anyone have a electrical diagram?
Dirt Nap 10-14-2007 05:12 PM
Problem solved ---Thanks for all who helped this place is a great resource and community.
It was the factory alarm the was fried. I pulled out the fresh air system and found the alarm box. My neighbor who is a EE checked over the board on the alarm and immediatley found a burn mark under the diode. He replaced the diode and blown out tracer and we tested--Wella she started up!!!!! Then it was just the reassembly process and a test drive.
Now on to the dead radio it looks like a trip to a car audio place.
I will never hook jumper cables backwards again I can tell you that!!
