Will a 2.7 crank fit a 3.0 case?
As the subject reads, I need to know if a 2.7 crank, and main bearings will fit into a 3.0 case. I know I will need to use the 2.7 flywheel also, what else would have to change?
D
Donnie Currently Porsche-less.....
no. only in the early carrera/turbo 3.0 case, which used a 2.7 crank.
