1977 930 caliper pistons corroded
Hi, I'm rebuilding my 1977 930 brakes and noticed that the front caliper pistons are corroded so I need to change them, I'm assuming that the rears are in the same condition so I will also change them but so far I have only found the fronts at Pelican but have had no luck with the rears.
Does any body have an idea of where could I buy caliper pistons?. The P/N's I found are 911.351.918.00 for the fronts and 901.352.993.00 for the rears, are these OK. Regards Wmoon |
how badly corroded are they? They might clean up with some fine steel wool and brake cleaner for you to better evaluate the pitting. I just cleaned up pistons from a 356 project that have not moved in 25 years. They looked bad but after the clean up, I only had one small area that needed buffing with a fine grit emery cloth. They now look brand new!
Tony G 2000 Boxster S |
Tony,
Thanks fou your suggestion, the pistons have "deep" corrosion that both my mechanic and I believe is enough to justify new pistons front and rear. My 930 has a european spec. 1978 engine with 300 hp at leats, it flyes and I want to feel as safe as possible with my breaks. |
put some SC calipers on unless you really need the aluminum flexy ones for some reason.
These should certainly be readily available and inexpensive as well. Very good suggestion.
bolts right on.
Or, you could bolt on 3.2 Carrera 'wide-A' calipers and 24 mm thick rotors for a bit more thermal mass ...
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Agreed. Those aluminum 'S' calipers flex like crazy. I have / had cars with them. If you want to retain them (for originality sake) Stomski Racing sells stainless brake pistons at $220 for 4 to repair them.
If you drive it hard, upgrading to the steel calipers (at a minimum) is the way to go. Tinker |
