mnmasotto's Avatar
Calling all wheels spacers experts.
Please help! What size spacers will I need to put on a set Cup 1 17X7 front and 17X9 rears with 55mm offset. My car is a standard Carrera 3.2. I have done three separate searches but cannot find any useful info. Any help would be much apprecriated.
Thanks, fellow pelicanite Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 10-07-2007, 02:16 PM
1" front (21mm is OK).
2" rear (42mm is OK).
Worked on my 82 SC, Carrera has same fenders.
Old 10-07-2007, 04:43 PM
chrisp's Avatar
the ideal offsets are:
7x17 = 23.3mm
9x17 = 18.6mm
Your wheels being 55mm front and rear, ideally you'll need a 32mm spacer front (32mm + 23.3mm = 55.3mm) and a 36mm spacer rear (36mm + 18.6mm = 54.6mm). These are ideal but may not be available.
Depending on what size tires you run you'll have a few mm of play in either direction.
'83 SC
Old 10-07-2007, 05:51 PM
Jeff Alton's Avatar
I am not sure that 23.3 and 18.6 are "ideal" but they work well.
Cheers
www.turn3autosport.com
Old 10-07-2007, 08:38 PM
chrisp's Avatar
thanks for mentioning that Jeff. The front is the factory offset for a 7x16 (works fine for a 17) and the rear is the Fikse offset for a 9x17
'83 SC
Old 10-08-2007, 05:38 AM
chrisp's Avatar
tcar, what tire sizes are you looking to run?
'83 SC
Old 10-08-2007, 05:39 AM
