Whats the best oil for the 915 5speed transmission
Hi, I was just wondering whats the best grade and type of oil for the 915 type 5 speed gearbox?, ive been told that by using a thick 80/90 hypoid oil it can be hard to select gears sometimes?
Shawn,
1976 911 targa 2.7
1979 :rolleyes911 3.0 coupe
Old 09-23-2007, 07:14 AM
GrantG's Avatar
Swepco 201 is the unanimous choice (don't know if it's easy to get in Spain). Pelican sells it...
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 09-23-2007, 07:31 AM
Hi, Is that a hypoid gear type oil? or a special type, ive never heard of that here, do you know the grade of swepco, ie 75/80 or 80/90 etc
Cheers.
Old 09-23-2007, 07:39 AM
GrantG's Avatar
Use the 80W/90:
http://swepcousa.com/lubesite/products/h201.htm
Available at Pelican
Old 09-23-2007, 07:43 AM
ok cheers for that.
Old 09-23-2007, 07:51 AM
Geary's Avatar
In Spain you should be able to easily obtain Castrol LSX90. This dino oil is much less expensive than imported Swepco, with a good reputation for high pressure protection.
While the 915 doesn't have a hypoid R&P, hypoid oils have good high pressure protection.... which is why they're highly recommended for small-geared early Porsches.
Old 09-23-2007, 09:39 AM
Swepco is highly recommended by some of the best 915 race track tranny rebuilders in the US.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-24-2007, 01:58 AM
I've got a similar problem in that Swepco isn't readily available here in Ireland and would be terribly expensive to import it from America. I will try and look for the Castrol LSX90 which Geary suggests, but if I can't find that does anyone know of any other Europe available Swepco alternatives?
Charles
'84 911 3.2
Old 09-24-2007, 03:08 AM
Geary's Avatar
Castrol LSX90 is readily available in Europe, but not available to us here in the U.S.
Old 09-24-2007, 07:43 AM
naturally aspirated
Palum6o's Avatar
I switched to Swepco 201 earlier this year. It did help smooth the shifting a bit into 2nd, especially when it warms up. This also took a couple months to notice it, does the fluid need to "break in" a little? Also, is it normal to have a drip or two leak out every week or two after a change? I didn't have a leak before?? I'm wondering now if I should have it checked. I have also confirmed that this car does much better off driven frequently and hard at times rather than sitting in the damn garage, like women and sex...
Old 09-24-2007, 07:46 AM
pete917's Avatar
Swepco do synthetic and non synthetic. Which is best for the 915?
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 09-24-2007, 09:00 AM
durn for'ner
livi's Avatar
Non synthetic. Like the 201.
Markus
Resident Fluffer
Carrera '85
Old 09-24-2007, 10:23 AM
JBO JBO is offline
Most importantly, if you use anything other than Swepco your trans will not go into gear, and will self destruct in short order....
Old 09-24-2007, 10:56 AM
