Push rod tubes for 911?
Hi all
I've just seen a kit a push rod tube kit (spring loaded expandable tubes) that replace the factory oil return tubes in VW Beetle engines. I also saw another type of expandable oil tube using some kind of internal thread in order to reach the right length. I wonder if there is something similar available for Porsche 911. I really think that the installation of these tubes would be much easier than the regular expandable tubes. isn't it? What do you think about this product? Dependable for Porsche engines? Regards. |
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg1.htm#item3
These are available from our host.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
