-   -   86 heated seats do not work (http://forums.pelicanparts.com/porsche-911-technical-forum/368996-86-heated-seats-do-not-work.html)
BRP83SC 09-25-2007 09:32 PM
I have a pair of two way power seats with heat. Power works for the the two-way but the heat portion does not work in each seat--what are the odds that its the relay?
I am and will continue to trouble shoot, but wanted to ask since 911 have well documented know issues and I wanted to see if this is one of them.
We are entering Fall here in southern cal ;)
BeauBlues 09-25-2007 10:51 PM
Heated seats in a carrera???? That's news to me.
dorschman 09-26-2007 04:15 AM
mine has heated driver's seat that does not work. I have read prevous posts that entailed going over each heat wire looking for a short or break. Sounded tedious but effective. I have not bothered myself as my car is mostly stock and the heater works like a nuclear reactor.
erik
BRP83SC 09-28-2007 07:20 PM
heated seats in sc
BeauBlues, they are originally out of an 86
911Mac 09-28-2007 09:05 PM
Any chance the power for the heated seats is a seperate circuit and just not connected?
-Mac
3.2 CAB 09-29-2007 06:54 AM
Sounds like it is time to get out the ol' circuit tester and check the heat leads and such.
BRP83SC 09-30-2007 08:34 AM
The 86 seats that I have a powered by two leads--1 coming from the number 1 fuse and the second coming from the number 2 fuse.
I purchased a wiring diagram for the an 86.
Yes, it looks as if I will need to test power and such within the system
Thanks for the input
Brad
