fuel gauge
1986 Carrera fuel gauge low level light does not extinguish regardless of amount of fuel in the tank. Level indicator is working correctly.
If it is a problem with the sender, can it be repaired? How do you determine if the gauge or sender is at fault? Thank you |
If you pull the plug from the top of the tank sender, and the light goes out then the problem is the sender. If the light stays on then you have a wiring problem.
The sender is easy to remove and disassemble. Rob |
If you need to replace the unit, here's a good walkthrough of the removal/installation - https://youtu.be/RbGRrPJDhmk. Done it myself- easy. Only comment about the video is ALWAYS replace the gasket!
