Super Moderator
cstreit's Avatar
Weird 2.7 oil leak - care to speculate?
So a friend of mine has a 2.7 CIS car and had a very strange oil leak that I simply cannot figure out where this might be coming from before we tear into it.
Symptoms:
1. Leak appears to be coming from the top of the engine, running down near the #5 cylinder at the head/cylinder junction.
2. While running on the track, there is a "regular drip".
3. With the car tipped heavily to that side, the leak doesn't get any worse
4. If you jack up the rear of the car, even with the engine off, 5+ tablespoons of oil will run out of this area onto the floor.
So with the oil pouring out in scenario #4, this seems to indicate that the oil is pooling up somewhere. However what stumps me is that there isn't really an area for oil to pool between the cylinder and the head, nor is there a "channel" for it to run from somewhere else into this area.
Anyone care to speculate?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 09-28-2007, 07:41 AM
moneymanager's Avatar
A problem I had partially fits your description. On my 2.7 we found a small hole in the very small diameter "spring-like" round gasket between the head and the cylinder. Not sure if that seal was defective from the factory (it had been in for about 3k miles) or if somehow it just failed in service. A small hole had actually been burned thru it. And it did lead to a tiny oil leak.
I don't know what to say about the pooling. Could oil collect on one of the deflectors somehow and then move when you lift the car?
Jim Taylor
Old 09-28-2007, 10:58 AM
When the pressure sending unit (for the idiot light) on the top of my 2.7 started leaking, it would leak at a very constant rate with the engine running and would continue to drip for a few hours with the engine off.
PorschePilot
74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration
MID9 Member
Beechcraft V-Tail Bonanza
(Fly'n high and low)
Old 09-28-2007, 02:08 PM
Another area that you might want to check is the rocker arm shaft for the cylinders in this area. If the swedge bolt loosens, this can be a leak source.
Old 09-28-2007, 02:18 PM
Navin Johnson
TimT's Avatar
thermostat
the oil seeps , and pools around the breather tower. btdt
'69 911 GT-5
'75 914 GT-3
and others
Old 09-28-2007, 02:28 PM
