Oil change on a 964
Hello
Is the oil change procedure of a 964 the same as an 911/3.2?
Do you have to drain the engine & the seperate oil reservoir
What kind of oil chould be used for this car?
Regards
Porscheke
Old 09-27-2007, 12:06 AM
basically the same. oil tank first, then the engine. then there's the filter issue. when you remove it, a torrent of oil pours out over everything, unless you punch a hole in the outer edge of the filter and using a rubber tipped airgun, blow the oil back into the tank for about one minute. keep the tank drainplug out and collect the oil in a pan. then there is virtually no mess. don't forget to put the plug back in though.
206 637 4071
Old 09-27-2007, 07:12 AM
Senior Member
Superman's Avatar
I've watched this procedure. Do yourself a favor and punch a hole in the top of the filter while the tank drain plug is out. I think the alternative is about two quarts of oil into the engine compartment.
Mocha 1978 911SC. "Coco"
Old 09-27-2007, 07:34 AM
dan79brooklyn's Avatar
Does the 964 take the same oil filter as an SC? I have a mahle left over from the 'old' car...
Also is their more than one oil filter on the 964? I thought there was another one mounted to the engine??
I ordered the Bentley book on the car, but it hasn't arrived yet....
I finally got proficient about changing the oil on my SC and now I have to worry about new jacking points and 'Gushing' oil filters!
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 09-27-2007, 10:05 AM
same filter. 993s had a second one where the oil cooler lived on the 3.2 and earlier engines.
206 637 4071
Old 09-27-2007, 10:12 AM
Metal Guru
911nut's Avatar
Ahh, yes "Without Guesswork". The Bentley 964 manual.
Definately written for a different type of Porsche owner (not necessarly one that frequents this bb).
Should you ever run out of toilet paper it will come in handy. As for using it to even change your oil, I'm sorry to say that your out of luck.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-27-2007, 02:29 PM
