-   -   Do I have a pedal cluster mismatch? (http://forums.pelicanparts.com/porsche-911-technical-forum/369443-do-i-have-pedal-cluster-mismatch.html)
Todd Simpson 09-28-2007 02:44 PM
I'm using a '71 cluster with a mag case 915, year unknown.
Will the '71 cluster provide enough throw for the 915?
76911S 09-28-2007 03:34 PM
Huh? For the clutch? They are the same through 86 except for the power brake set up, but even then the cluster is the same.
vash 09-28-2007 03:49 PM
not so sure about that. when the clutch cable changed so did the pedal cluster. helper spring vs. non helper spring 915. basically i dont know exactly what, but there are subtle differences.
Steve@Rennsport 09-28-2007 04:13 PM
Go for it,...you'll have no issues,...:)
JP911 09-28-2007 05:02 PM
The position of the arm that the clutch cable attaches to on the pedal cluster changed when they introduced the helper spring in 77 or 78. Trust me, I went through hell trying to figure out the problem when I installed an aluminum 915 in my 76. I ended up having to change the pedal cluster.
