Slant Nose Mechanisms 930 same as ?
I have heard the Slant nose mechanisms on the 911/930 are the same as a 924/944. I have also heard they were the same as the 928. Would anyone know off hand which are interchangable? Mine was changed out years ago to regular fenders & I want to go back to original, just have to get all the parts. Any help is appreciated. Thanks in advance.
no they are all 3 similar but not the same. when I swapped mine over to a slant I wanted to make as close to factory as possible. the car came with a spare set of steel slant fenders, and mazda linkage. So after looking a a factory slant and seeing the very close similarity of the linkagesI bought a full set of 944 linkage lights and motor. the motor is the same. the light buckets are simiilar but a different size. I would have been better off tossing the fenders and buying a whole set from a wrecked slant nose. So IF you decide to convert back ..wait until you see a complete set up on e bay or someplace. then buy it. wait for the whole thing you see fenders fairly often and someitmes the whole set up. but you NEVER see individual parts. and when they are selling the whole set up they are never willing to sell just parts. I looked for the linkage parts for almost 2 years before giving up.
I bought a set of Slant fenders. The funny thing is they have the OEM #'s but it also has an actual bucket that seals off, save the 2 holes in the bottom for wiring, the rest of the headlight from the fender well. As I studied them, they have the Mazda RX7 motor set up. I know that many had been set up with the Mazda or Denso motors, but is the Mechanism Mazda as well?
not sure if the mechanism is the same or custom made for it does yours have the round or square lights?
Round lights, looks like 2nd generation RX7 motors. I would guess these are RX7 mechanisms as well?
your best bet is install them it could be several years before you are able to find a factory set up. Really not that hard once you figure out the wiring and how to hook up the relays etc. I set mine up so that the first click on the headlight swtch opens the light buckets and the second click actually turns on the headlight. that way you can open them to change bulbs or clean them without having them lit. I found the headlight wiring schematic for a mazda online after that it was fairly easy to figure out. I think someone from rennlist e mailed me the link, i'll look when I get home.
Ken, if you could post that it would be a huge help. I'm having trouble with my slant/mazda setup, and haven't made much progress on finding the problem.
John |
Ken, I would also like to see your wiring schematic. Question, are these the Mechanisms from the Mazda as well?
yes I couldnt find the link to the page with the schematic I'll have to look for it . basically you have 4 wires to each bucket. a ground a 12v to the battery then 2 12v lines to the relay one is energise to open the other is energise to close. I tested each one out of the car by hooking the wires to a battery charger to verify I had it right. I installed a relay in the front trunk that has the energise to close connected to the parking lights. so that the first click opens them up then the second click turns them on. I might have found the schematic doing a google search for mazda lights. or rx-7 wiring schematics
If I'm reading you correctly then what you have are probably factory fenders w/the Mazda headlight units. These were probably sold through Alan Johnson Racing back in the 80's. My 930 has these and it was my understanding that they were sold this way as part of a conversion package offered by AJR. You could have also opted for the single motor mechanism from the 944 or 928 which ran a few more dollars. To me, the biggest value is in the fenders.. they're factory stamped units. The Mazda motors, while non factory ar very simple units and easily replaced. It's a lot of work to find all the correct pieces and install the factory set-up single motor set-up... I haven't really seen any on "sleezebay" and most that I've seen wrecked have been smacked in the front. P- |
Nice to know where these came from. I will be running the Mazda setup. It does as you say look simple. I actually just bought another set of RX assemblies for parts, since a few were missing on my fenders. They seem more self contained & as long as they work, I'm good. But, as I have asked not recieved answers to. Are these Mechanisms Mazda?
Mazda motors were used by many aftermarket fabricators. The lift mechanisms were typically custom made. To my knowledge all have a some level of shake when up and driving.
oh and the steel fenders are not always factory fenders. If you look underneatht them they are usuall stock fenders that had the bulges cut off and a semi flat section welded in with the louvers and the hole for the lights. the hole is very close but not exactly the same as the stock ones. if they are after market the section where the louvers is installed is NOT galvenaized on the underside.
your linkages are much different from mine and those are definately not factory steel fenders. I like the way yours is set up much better
Ken,
Most of the steel fenders are not factory which is exactly the point I was making. There are some out there that are..but still did not use the factory light mechanism. You are correct in that the tops of most fenders were cut-out and and a flat section with louvers and light bucket welded in. I did that to a 77 turbo I had (w/spare set of fenders). Typically if you run your hand underneath... you can feel, or if the car is on a lift with a wheel off, you can see the seam where slant insert was welded and hopefully sealed. I've also owned a late Turbo w/ factory slant option and now my current 930 w/AJR conversion that used factory fenders with Mazda lights. Both had/have stamped galvanized fenders. |
mine are the welded ones the louvered section isn't galvanized but you couldn't tell until i had stripped them for painting So I re coated the underside with that wurth bare metal anti rust paint similar to the por 15. then it went for the regular primer/undercoating etc. that the fenders normally get. the holes are slightly different from the stock holes so they couldn't be adapted to the stock linkage the difference was about 4 mm or so just enough to not fit but not enough to tell without measuring. the ones picture above are even better they keep the mud out of the back of the lights, I am still trying to figure out how to make some sort of fender liner that looks decent but is still functional and doesn't weigh a ton. The stock fender liners are also NLA
So the Part # is Bogus?
Would that not be a 930 Slant?
HI Akila,
this mechanism and motor look exactly like mine. Did you have a chance to find the source for this motor. If you do, please let me know. I am looking for one. Thanks. Quote:
These are the RX-7 Motors. I have not set them up as of yet, but the motors are readily available on Ebay. Let me know if I can assist further.
Akila,
Thanks for response. Do you know which year is this one? I saw many Mazda motor on ebay but they are not exactly the same (the 3 mounting points). Also, yours look so new. Do you know any place to get it new? Thanks Quote:
Don't know where to get new ones. I had picked up an extra set just in case I need parts. IIRC these are the latest year with the rectangular headlights. I bought a complete assembly of Mazda's, but I forget what it cost.
Do you remember what year is the one on your pics, above?
Dont recall. I will go dig em out later & look for a part #.
Here are a picture of the actual motor from the slant fender. Hope this helps
http://forums.pelicanparts.com/uploa...1204154428.jpg |
I have exact same motor, which doesn't work anymore, and I don't know what year it is from.
Thanks Akila. |
For some reason I have 87' to 94' in my head.
Akila,
no... umm... I don't know exactly what year but those on ebay posting 86-90 are not the same as this one. The 3 mounting bolts are not mounting to the body but they have arms. |
This look like what you are looking for. Click on the small picture.
http://www.********.com/catalog/raframecatalog.php?carcode=1192250&parttype=1412&a =FRc1192250k920901 |
So it looks like out motors came from the first generation RX-7. The year selected for the ******** website was 1982.
Also, I found out there was a fat & skinny motor. Apparently the ones to use are the skinny ones. 1979-1985
Look like that what it is. Thank you Akila.
It's RX7 from 83 to 85. I ordered and installed it in. The headlight works now.
Thanks Akila, thanks all. |
Would you happen to have a wiring diagram of your lights?
My car was premade that way, with the same motor. I didn't change anything, just cut and reconnect exactly how it was before. I didn't even have to do any measurement because all wires are the same collor. Sorry don't know how to help. If you can think of any way I can, let me know.
mazda motors, RX 7 early version. when installing them in a porsche, take care to seal the relays completely with silicone as they are mounted upside down from their original position. Otherwise these relays fill with water, corrode and fail
the swivels/ hinge points need to be lubricated periodically too |
TRE, I'll keep that in mind, if & when I ever get around to mounting the Slants.
rnln, Where did you end up buying the motors, price? |
| All times are GMT -8. The time now is 03:57 AM. |
