911vet's Avatar
Sporadic momentary power losses?
Thoughts on what this might be?
I suddenly loose power for a few seconds. It happens very sporadically and mostly when I'm in 4th or 5th at about 3000-4000 rpm.
Everything is fine, then power cuts out for a few seconds. My tach doesn't change during the event.
The first time it happened was a few seconds after I misshifted into 2nd gear going 50mph. I don't think I buried my tach into the red, but it was a pretty serious "oh sh**" moment! I got it into 3rd and was accelerating when I lost power. A minute later in 4th gear it did it again. I shut the car off and when I restarted and got into 5th gear, it did it again.
Since then it's happened a few more times.
What could I have done at that misshift to cause a sporadic problem? Or do you think it's a coincidence?
I can't figure out if it's a fuel or fire problem. But I'm thinking I should replace my fuel filter and DME and fuel pump relays. Would an 02 sensor do this?
Thanks.
Shannon
87 911 Carmine Red -- Recaro Pole Positions, Schroth 6pt, DAS roll bar, Rennline Strut Brace, Bilsteins, Borsch cat bypass, Fabspeed airbox, MaxHP Multiboard. MidOhio, Gingerman, Putnam.
Old 09-30-2007, 09:09 AM
Fidalgo911S's Avatar
Double check the battery connections. I did a high rpm shift on my '74 once and the power cut out. I thought the rpm's did it but I found out I had a loose wire on the positive terminal.
Nate
Old 09-30-2007, 11:10 AM
