1987 gear oil change Redline!
Newbie here. I changed gear oil last week on my 87, I am quite certain that it had never been changed previously, 28k on the car. The caps were a nice battle that finally gave into a large cheater bar, heat, and oil.
I went with Redline 75-90ns which is what they recommend for p cars. I have always had great results with redline in spec Miatas and found the same to be true in p cars. It shifts much, much, easier and smoother when cold and cut trans noise to nothing! I am sure what was in before was factory fill, and does not compare to modern synthetics.
1987 Targa just about to hit 29k
2004 mazdaspeed miata wifes
1995 spec miata SOLD stupid fun!
Old 11-16-2009, 03:07 PM
nineball's Avatar
when i changed mine last week i found the po had filled it with mtf. you never know what you are going to find until you do.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-16-2009, 04:08 PM
I've used Redline in my 87 with mixed results. It seems to work great at the beginning say for 10K miles, then drops off (more noise, hard cold shifts).
I've since switched to the 'hard to find' Mobile Delvac 75W-90, this fluild seems to work better in IMHO.
Old 11-16-2009, 04:18 PM
nineball's Avatar
that's what i am using and so far so good but it has been less than 100 miles since the change. my 2nd syncro is worn and it would take a good effort to get into 2nd gear, about 5-6/10 times but since the change it is 1-2/10. it's quite easy to find here, i just went to autozone and picked up 3 bottles.
Old 11-16-2009, 04:25 PM
