High Idle - CIS issue
I have been having a problem with my 1980 SC. When cold, it starts up, but only idles at around 600 RPM, and sounds like it's going to stall. After driving it down the block, it settles into an idle of around 1100. Once warm the idle goes up to about 1250, and stays there. I have tried adjusting the idle screw until it is closed, but still can't get it to go below 1200-1250 RPM.
I have checked for vacuum leaks, using carb cleaner on the intake boots, vacuum hoses, the airbox and fuel injectors. I have also examined the AAR when cold, and it is opened, and when warm, it looks to be closed. One thing I was told, is that the Vacuum housing on the distributor may be no good, but would that not allow me to adjust my idle? Where else should I be looking, and what other tests can I perform? Thanks |
barring that you don't have any vacuum leaks that you know of, yes the distributor advance/retard weights could be stuck. You can test the retard easily by sucking on the line, the advance though us not as easy, it'e very hard to see it move. The best way to insure the advance s free is that the rotor when twisted should "spring" back into position.
According to PET you should have a vac limiter fitted, you can adjust your idle from there. Loosen the lock nut, loosen the hoseclip a bit, screw the rod down and see if it makes a difference. Stop when you get to where you want. You are going to have to open that idle screw a little bit if you haven't just left it where it was.
The vac limiter is the bit with the hose coming off the top of it. It tees into the thermo valve and the throttle body - spot the connection. http://img.photobucket.com/albums/v2...Rwork065-1.jpg |
Isn't that the decel valve? It controls the rpm's from dropping to fast.
Whatever you call it, it vacuum-assists the revs, so try adjusting it if you have it fitted. |
2nd on the Deccel valve.
Check your vac routing again. Pelican has the diagram online for FI 911SC. It's critical especially to that electric switch on the heater fan mount. If you're sure that everything is right then the only other thing I can think of is the intake runner injector seals. Not the ones with the rubber O rings on the injectors themselves but the ones that hold a seal to the runner to phenolic tube that the injector slips into and is held in by the fat o ring. There's a thread on how someone replaced them. It makes a difference. I imagine the idle on your car is compensating for a leak like this thus the idle goes super low at cold after the AAR closes up after a few minutes. When the motor heats up everything expands and you get your warm idle. Wouldn't hurt to make sure the popoff valve is secure. Check the runner boots too if you can get to the screws. I wish I could speak from experience that it will solve it but it's the last thing I have to replace an my CIS. I curse myself for not doing it 40K ago when I did my engine rebuild. Hope some of this helps. |
I had the exact same symptoms on my C3 - was the vac limiter. |
Oh yea. It's easy to see if the vac on the dist works. Suck on the port with the dist cap off and see the swash plate move.
You can also test it by plugging the vac line to see if that makes an idle difference. |
Also, check the (what used to be called a) breaker plate to make sure it moves smoothly. If it is stuck, your vacuum advance and/or retard will not move smoothly, if at all, and that can complicate your problem. Matt |
You've got a big leak. It has to be something simple like a hose off. The idle adjustment screwed in all the way should kill the engine.
I had a problem similar to yours a few weeks back...changed out WUR, AAR and AAV....to no avail. Finally found out it was a bad relay on the circuit that controls the heater element on the WUR and AAR....they essentially remained at their cold setting and made a real nice vacuum leak when warmed up.
It is a black one, easy to check, it is on the rear panel in my car ('75) Dennis |
Scott,
My car used to run very similar to the symptoms you describe - especially closing the idle screw and still having a fast idle. Checking the advance weights is a very good idea, but what oneblueyedog said was what finally fixed mine. It was caused by air leaking in around the phenolic tubes that hold the injectors. I was amazed at how bad these looked. You can pull the injectors and change their seals, then pull the phenolic tube that holds the injectors. Mine were old, crusty, and the seals were worse. The car ran like new after I fixed these. |
Tighten and replace the cheap stuff first.
Good luck. |
The diagram above is not for a US 1980 SC. |
I see some mention of checking the injector and injector sleeve seals. I have already switched out the injector o-rings, but have not replaced the seals on the sleeves. I would have though that by spraying carb cleaner onto the injectors, and seeing no change, that I could rule out these seals.
Additionally, I have looked, but do not have a vac limiter. |
Hmmm.
Pipe 46 in the diagram rubs against the fan housing. It may have rubbed a hole through. Fixed mine with JB weld. Rubber hose 43 gets aged and cracked Tighten up all of the clamps to the hose ends to where they are immovable 12, 15, 19, 20,44, 45, 48, I have a clamp on 47a and b Replace all of the Vac hoses with German hose. Make sure hose 13 goes below throttle plate and 13b goes above. Get a mirror and look behind the throttle plate to see if there are open vac ports. Cap them. Do you have a pop off valve? Do you have a cracked air box from a backfire? Check the vac line to brake system for leaks. Check boot 18 fro cracks. Check the tightness of clamps on the intake runner boots. (PIA and you may have to do a partial engine drop.) Just throwing out ideas. I've felt your pain. I used starter spray to vac leak check. RPM's went up. Got a pic of your engine bay? |
This is the 80" sans part 8A which was used in 82 and 83 http://www.pelicanparts.com/911/911_...8-83/1-7-3.JPG |
Has this recently started, or has it been this way since you had the car? Did a shop do some work on the car prior to this?
You should check your AAR, since your start/warmup idle is a little low, also your WUR/cold & warm control pressures. Most importantly, I also think you probably have the later type of decel valve, and an AAV. They are on the passenger's side of the engine. Older cars had the earlier one on the left as someone showed. Check the later version of the SC CIS diagram on this site. These things are oriented horizontally and look like thick disks. Check to see if all hoses are connected. These Decel Valves (aka vacuum devices) can be fixed by gently squeezing them in a vice. Search this for more info. |
| All times are GMT -8. The time now is 11:22 AM. |
