Floor board bolt broke
While removing my drivers side floor board the bolt that holds it on broke. I thought I could just remove it and put in a new one but I can't seem to get it out. Any suggestions?
Kirk 78SC |
floor board bolt
The bolt is passed trough the floor board and the head is welded to floor board. You have to grind the head off on outside and insert a new bolt with a nut inside.
Fritz 1966 912 Irish green 1972 911T bare metal, work project |
That's what I was thinking but I figured I better check.
Thanks Kirk |
My bolt head (Allen) is stripped. Anybody have the full specs of this seat rail bolt ('89)?
Thanks,
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
