Porsche Bodywork Guys...best method of sanding? Tools to use?
Hi all,
I'm sanding some filler from my newly welded on flares. I know block sanding is the correct method, but there are virtually no flat surfaces where I'm sanding. What are you guys using to sand? Any special tools? |
I like starting with a 16" sanding file using 40 grit. Make sure you sand in different directions. I like to cross hatch across the valley. Then I move to 80 grit with the same file and finally I take 150 grit and nice round object like a role of 2" duct tape with the sand paper taped around it. I sweep the role downward across the valley.
go to the paint store and get a 6" soft sanding pad they work wonders for the contors
Here is a good website for autobody help and questions:
http://www.autobody101.com/forums/ Interestingly enough I read a thread from someone asked about using a palm (jitterbug) sander. The feedback was unanimous concerning that tool…absolutely no. Anyways, that was their opinion Jim S. |
| All times are GMT -8. The time now is 04:04 PM. |
