CIS Fuel Pump and carbs
I've done the search and all indications are that with the proper pressure regulator (PMO) and a recirculating fuel system, the CIS pump can be used with carbs. I just wanted to verify this type of system before I burn the car down.
Thanks, Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman |
19 years and 17k posts...
My mechanic (Tab Tanner) recommended that we switch to a low pressure, high volume electric fuel pump and a new pressure regulator when we switched to Webers. Sell your CIS fuel pump and help defray the cost of the project as the replacement fuel pumps are cheap!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I've used the original CIS pump on my '76 for almost three years now with the PMO bypass regulator with no issues. Very good pressure regulation. Simple and reliable.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red |
Slippery Slope Victim
Same here
MikeČ 1985 M491 |
AutoBahned
Yes - it works fine and is a very high quality pump. You may want to relocate it to the front to deal with hot start issues in summer.
Richard Parr (Mr. PMO) told me to NOT ditch the CIS pump when I asked if I should switch to a low pressure, high volume electric fuel pump. So that is the word of the designer... search on Racor for a nice fuel filter. |
I used the CIS pump with my PMOs for about 6 months before the pump gave up the ghost, which I don't believe had anything to do with the carbs but rather old age. I used a Holley for awhile and I now have a Carter, and I honestly regret not having just replaced the CIS pump. The Bosch pumps for our cars are well-made.
Thanks for the advice, I'll use the pump without fear.
Jim S.
+1 on the Racor. Great filter, easy to maintain.
Jon |
+2 on Racor. Check marine suppliers, get the smallest micron possible.
MikeČ 1985 M491 |
