Drilling antenna hole in '68 fender
Hi all, can someone provide some measurements for drilling a stock antenna hole for a manual Hirschmann on the drivers side fender behind the fuel filler?
And yes, I know about amplified antennas, but I want to mount an antenna in the stock location, so I need the hole. Thanks for any help! |
Mike-
I have my '68 in the paint shop right now, and I welded up the antenna hole, but the fenders are off the car and I can still get a measurement on the underside to the center of the plug, if you can wait until Monday, when I will be going out to the shop again. Maybe someone else can measure theirs before then for you, though. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
why not mount it inside the front trunk, across the cowl? no hole needed unless you're into AM radio.
Tom, I can wait, thanks for your help! Let me know.
John, actually I DO listen to AM. Mainly for Cub games. |
Mike-
I measured 10-3/8" from the rear tip of the fender to the center of the old hole for the antenna on Monday. Unfortunately, I forgot to reply to this thread until today. Sorry! ![]() TT
A belated thanks for the measurement! I will compare it to some other references I have and then bust out the drill.
