Does anyone know what the torque setting is for the fastening screw on the B-pillar? I just removed my harnness bar.
I don't want it too loose, but if I torque it about 45 ft-lbs, the belt doe not rotate on the hinge. Thanks!
1989 Carrera 3.2 Silver Anniversary Edition 2007 BMW 750Li 2005 Honda Odyssey EX-L http://forums.pelicanparts.com/porsche-911-technical-forum/285064-new-member-have-pics.html |
What year? '89?
Best
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
THE IRONMAN
This attach bolt will work in shear load, right...! If so...the torque value don't need to be excessively high...IMHO...
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Doyle- looks like we have the same Edition...
Syl- I guess you're right; just tight enough to have some movement in the hinge...
1989 Carrera 3.2 Silver Anniversary Edition 2007 BMW 750Li 2005 Honda Odyssey EX-L http://forums.pelicanparts.com/showthread.php?s=&threadid=285064 |
