-   -   what thread size is this part (oil sender) (http://forums.pelicanparts.com/porsche-911-technical-forum/371214-what-thread-size-part-oil-sender.html)
djtalon 10-09-2007 12:02 PM
it is #52 in the pic. Its the throu bolt for the oil pressure sender. Seems like mine may be stripped, anyone know the tread size?
http://www.pelicanparts.com/PartsLoo...-10-Frame5.htm
Jim Sims 10-09-2007 07:53 PM
12 x 1.0
http://forums.pelicanparts.com/porsche-911-technical-forum/57130-stripped-mag-case-where-oil-line-gos.html?highlight=sender
Were you trying to remove the oil pressure sender with the mounting block still attached to the case via part #52? The threads in the case may be stripped.
