what thread size is this part (oil sender)
it is #52 in the pic. Its the throu bolt for the oil pressure sender. Seems like mine may be stripped, anyone know the tread size? http://www.pelicanparts.com/PartsLoo...-10-Frame5.htm |
12 x 1.0
Stripped mag case where oil line go's Were you trying to remove the oil pressure sender with the mounting block still attached to the case via part #52? The threads in the case may be stripped. |
