-   -   Will this heater backdate part work on an SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/371252-will-heater-backdate-part-work-sc.html)
lfot 10-09-2007 03:14 PM
This part number is listed as fitting an 84-89 Carrera. Does anyone know if it will also fit an SC 3.0?
Part number:
930.106.321.02
Here's a link to the part:
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&co mmand=DWsearch&description=930.106.321.02&I1.x=15& I1.y=10&FILTER_911E=ON&FILTER_911M=ON&FILTER_911L= ON&FILTER_996M=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FI LTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_ PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL= ON
lfot 10-09-2007 03:59 PM
would a picture help?
http://forums.pelicanparts.com/uploa...1191970728.jpg
Staylo 10-09-2007 04:11 PM
For an SC, I'd use this one:
930-106-321-01-PH
lfot 10-09-2007 04:21 PM
930-106-321-01-PH
You still have to get that part modified to fit around the 3.0 distributor.
Looking for a possible way around this.
Staylo 10-09-2007 04:27 PM
carefull use of a BFH works well.
Superman 10-09-2007 05:14 PM
The part I used is for a Turbo. The indented part is large enough for the SC distributor. Other ones are not.
lfot 10-09-2007 06:48 PM
Intended part? You mean the one I started the thread with? Do you have the part number of the one you used?
KFC911 10-10-2007 05:17 AM
I too used the Turbo left side hot air duct also: OEM-93010632102. Just FYI, the part you show above does not appear to be for a Carrera nor is it the Turbo part #...I think that's for an earlier car, maybe an SC.
