Anachronistic Anomaly
lfot's Avatar
Will this heater backdate part work on an SC?
This part number is listed as fitting an 84-89 Carrera. Does anyone know if it will also fit an SC 3.0?
Part number:
930.106.321.02
Here's a link to the part:
http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?please_wait=N&forumid=&threadid=&command=DWsearch&description=930.106.321.02&I1.x=15&I1.y=10&FILTER_911E=ON&FILTER_911M=ON&FILTER_911L=ON&FILTER_996M=ON&FILTER_TECH=ON&FILTER_SUPP=ON&FILTER_ACCE=ON&FILTER_CARE=ON&FILTER_STUF=ON&FILTER_PERF=ON&FILTER_MISC=ON&FILTER_GADG=ON&FILTER_TOOL=ON
IG@ the_derek_whitacre
Old 10-09-2007, 03:14 PM
lfot's Avatar
would a picture help?
Old 10-09-2007, 03:59 PM
Mocha BAP
Staylo's Avatar
Send a message via Yahoo to Staylo
For an SC, I'd use this one:
930-106-321-01-PH
Scott
71 911T Coupe 3.0 Looks stock
79 911SC Coupe 3.2ss Nothing stock
02 996 C2 Cab Mostly stock
06 955 CTTS Super P!G
Old 10-09-2007, 04:11 PM
lfot's Avatar
930-106-321-01-PH
You still have to get that part modified to fit around the 3.0 distributor.
Looking for a possible way around this.
Old 10-09-2007, 04:21 PM
Mocha BAP
Staylo's Avatar
carefull use of a BFH works well.
Scott
Old 10-09-2007, 04:27 PM
Senior Member
Superman's Avatar
The part I used is for a Turbo. The indented part is large enough for the SC distributor. Other ones are not.
Mocha 1978 911SC. "Coco"
Old 10-09-2007, 05:14 PM
lfot's Avatar
Intended part? You mean the one I started the thread with? Do you have the part number of the one you used?
Old 10-09-2007, 06:48 PM
I too used the Turbo left side hot air duct also: OEM-93010632102. Just FYI, the part you show above does not appear to be for a Carrera nor is it the Turbo part #...I think that's for an earlier car, maybe an SC.
Old 10-10-2007, 05:17 AM
