JE piston vs stock piston weight
hi all,
i have a 1978 911SC w/ JE piston (3.0, 9.5:1), and trying to compete in SCCA autox, BSP class.
the class specify the piston has to be "same dimension, configuration" and weight.
anyone knows if the JE piston is lighter than stock pistons?
thank you.
Old 10-15-2007, 02:47 PM
AutoBahned
RWebb's Avatar
lighter - I have posted wts. at http://www.penaltykicker.com/911/data/
which is graciously hosted by anther Pelican
Old 10-15-2007, 02:52 PM
JE 95mm 9.5:1 piston=417 grams.
Mahle 95mm=624 to 668 grams.
Schmidt 95mm=673 to 711 grams.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 10-15-2007, 03:15 PM
Jeff Alton's Avatar
My 98mm JE (10.5:1) were 424g....... Down some 200g each from the stock 95's they replaced.
Cheers
www.turn3autosport.com
Old 10-15-2007, 06:06 PM
Thank you for the input.
so, i am out of BSP.
now i will have to beat those SM2 monsters.
Old 10-15-2007, 11:44 PM
Wickd89's Avatar
Just wondering. What is the performance improvement with the reduced weight pistons? 20 more hp? 50 more hp?
What else would you replace if you swap these out??
thx, lg
Luis "once was - Wickd89"
Carrera 3.2 - "Faster, Stronger, Better"
-- 2008 Toyota Camry SE V6 (mine)
-- 2005 Toyota Sienna (hers)
-- 1989 911 Carrera Cabriolet -SOLD
Old 10-16-2007, 07:44 AM
David's Avatar
My 98mm long skirt JE's are lighter than the 98mm short skirt Mahle's they replaced. Sure makes you wonder about the longevity of the JE's.
Old 10-16-2007, 09:27 AM
Won Won is offline
Won's Avatar
I thought you were already in SM2?
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 10-16-2007, 10:08 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
I think the main advantage of the JE's is the increase in compression ratio.
Chris
73 911 E
Old 10-16-2007, 10:17 AM
i want to move to BSP, but i guess no more.
more realistic competition against you and Don's S2K.
btw, i found out a major reason i lost to you on Oct 13.
my engine starved for fuel in the afternoon which was much colder than the morning.
i had the same problem on last sunday driving to regional #5.
and, also, you drove better that day ^__^.
Old 10-16-2007, 10:45 AM
Mad scientist
Peter Bull's Avatar
Reducing the moving mass in the engine will reduce acceleration times in lower gears, because the reduced inertia will allow the engine revs to increase quicker. In higher gears you will not notice any difference.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 10-17-2007, 12:39 AM
