-   -   Tie Rod End Question (http://forums.pelicanparts.com/porsche-911-technical-forum/371567-tie-rod-end-question.html)
nickorlik 10-11-2007 10:15 AM
I'm in the process of completing a brake upgrade on my '81 SC including caliper rebuild & paint & rotor/pad replacement. Found one of my turbo tie rod ends shot. I was able get it disconnected from the arm, but I can't seem to get enough leverage with a wrench to hold the rod still to unscrew the end.
Does anyone have any suggestions to loosen the end? Any tools that would help?
midnight911 10-11-2007 11:28 AM
there's a recess on the rod where 12mm open wrench snugs... if it is seized, grab the tie rod end side with a channel lock and twist. apply heat if stubborn...
nickorlik 10-11-2007 04:25 PM
Thanks, I'll give it a try.
