-   -   Any one know where I can get this fitting? (http://forums.pelicanparts.com/porsche-911-technical-forum/371621-any-one-know-where-i-can-get-fitting.html)
dpegan 10-11-2007 04:44 PM
This is not a great picture, but it is a steel fuel line fitting that came off of a 911 SC. It has threaded flange male end with a barbed end for a hose fitting.
Does anone have a source for these?
thanks
http://forums.pelicanparts.com/uploa...1192144765.jpg
craigster59 10-11-2007 04:53 PM
Try here http://www.mcmaster.com/ around page 143-144
HarryD 10-11-2007 06:02 PM
Go to your local hydraulic hose shop. They have all kinds of stuff like that. If they do not, they can most likely make you one from two that each one has one correct end. Cost? Typically less than $20
dpegan 10-11-2007 08:06 PM
thanks guys,
this will make my 3.6 conversion a lot cleaner.
cheers,
dan
911pcars 10-11-2007 08:54 PM
Not sure if American pipe threads are interchangeable with Euro specs. If they are, your local hardware store should have these. Barbed brass hose fittings are quite common, but not on a Porsche. Could be something the PO installed.
Sherwood
HarryD 10-11-2007 09:08 PM
Sherwood
Sherwood,
Many of the hydraulic hose shops in my area carry metric fittings. Chances are they have what he is looking for off the self.
After revisiting this post, I am wondering what the fitting is for. If it is for a high pressure fuel line, a barbed fitting as shown is not the best selection. Maybe DPEGAN can provide us with the use to help him be sure of his selection.
