-   -   Bosch H4 Assembly Question (http://forums.pelicanparts.com/porsche-911-technical-forum/372005-bosch-h4-assembly-question.html)
hahnmgh63 10-14-2007 10:32 AM
Installing my Bosch H4's in my car after a year at the body shop (slow guy). He dismantled them to paint the trim rings. I am putting them back together and I think I may be missing a couple of springs? See pics. How does the reflector stay in place with the adjustment screws as they just flop around without some kind of tension on the reflector? Should each adjustment screw have a little spring on it? I can't find any pictures of the assembly on the internet and the PET Cd leaves much to be desired. TIA, MGHhttp://forums.pelicanparts.com/uploa...1192383072.jpg
http://forums.pelicanparts.com/uploa...1192383088.jpg
BeauBlues 10-14-2007 12:50 PM
The adjustment screws need a retaining nut where that rubber bushing is. Just get the correct size nuts, fasten them snugly against that rubber using loctite to keep them from coming loose.
The object here is to have the screw be able to spin freely, but also to keep it from coming out of the trim ring
