Scott R's Avatar
Brake piston orientation
I'm getting around to sorting out a big box of parts I aquired and I was going to rebuild these calipers, but I believe the pistons are 180 deg off. Anyone know by looking at the picture? They should be clocked the other direction at 20 deg I think.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-30-2013, 05:58 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
looks right
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 01-30-2013, 06:05 PM
Scott R's Avatar
OK, I flipped the caliper and put the tool in according to what I believe the picture means.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-30-2013, 06:17 PM
porsher
aston@ultrasw.c's Avatar
I don't have a caliper in front of me but....
Decide if the caliper is intended for the left or right. Orient the caliper as it would be mounted with the bleed screw at the top. Now insert the tool.
Imagine that the rotation arrow in the diagram intersects with the cutout at approx 90 deg.
If you are still not sure print the diag and tape it to the fender where you are working. On the passenger side the ink will be on the outside. On the driver side the ink will be on the inside.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 01-31-2013, 07:38 AM
Scott R's Avatar
Thanks for that tip, I'll give that a try this weekend.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-31-2013, 07:46 AM
porsher
I'm glad that made some sense
79 928 Race Car
Old 01-31-2013, 08:18 AM
Yes do this!!!
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 01-31-2013, 10:14 AM
Scott R's Avatar
Is that from the FSM? That's perfect! Thank you both!
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 01-31-2013, 10:29 AM
If you look closely in the Bentley manual, you can see where the piston orients. I have been doing mine by eye for the past ten years(numerous track days led to many rebuilds) and have never had any issues.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 01-31-2013, 12:25 PM
Checked out
McLovin's Avatar
I've always done that, but never known the purpose!
Why does it matter?
Old 01-31-2013, 12:39 PM
The argument is that as the pads close in, the rotation of the disc will try to angle the pads, as opposed to having them lie flat against the rotor as the pistons push the pads.
I am sure there is an expert out there that can explain this better than I.
Bill Verberg, are you out there?
Old 01-31-2013, 12:56 PM
83 911 Production Cab #10
JJ 911SC's Avatar
If off the 20 degree line, they would squeal like little piglet...
Who Will Live... Will See
Old 01-31-2013, 10:02 PM
