-   -   O2 sensor protection plate (http://forums.pelicanparts.com/porsche-911-technical-forum/372052-o2-sensor-protection-plate.html)
01sport 10-14-2007 01:31 PM
What is the proper direction to face the O2 senor protection plate?
TIA
Jeff
Jascha 10-14-2007 02:56 PM
The shield portion (( should face the catalytic converter
cat (( sensor
Zef 10-14-2007 03:08 PM
It's a heat shield....position it to protect the sensor from heat...
01sport 10-14-2007 08:21 PM
The O2 sensor screws into the CAT. The plate cannot protect it from heat. I doubt that there is a hotter place on this car. I think the protection plate is to guard the O2 sensor from rocks kicked up in the wheel well and that it should face the tire but I'm not sure.
vintage guy 10-15-2007 07:42 AM
In my car, which I believe to be original, the shield is snapped onto the O2 sensor and faces outwards towards the tire, not the engine. I think it is there for protection against road debris.
madmmac 10-15-2007 07:49 AM
Indeed, debris protector...towards the wheel.
dshepp806 10-15-2007 11:10 AM
yep,..debris protection (not heat).
Best,
hcoles 10-15-2007 01:29 PM
yes..debris protector... exactly what angle it should be is a good question...I usually put it "facing" a bit toward forward... assuming rocks would come from that direction..
don't loose it... they are hella expensive for what you get.. ops.. can I say hella on this forum...? sorry, been listening to my kids too much about 5 years ago.
