tar on my car... opinions requested..
Our county has been tarring many roads around here and I ended up driving through some of it that had dribbled downhill onto my driving lane. Not possible to avoid while in traffic and I wasn't looking for it either. I'm pissed. It's also on my truck, but my car is clearly more troubling. I spent many hours getting it off the paint, but it's still in the wheelwells and under the car in places. I'm planning to file a claim with the county as it would have been a trivial thing to prevent this from happening with one guy and a mop or broom. There were plenty of guys standing around.... A couple of things...
1. Thoughts about cleaning. What to use? Somewhere I can take it? Any way to get estimates?
2. I'm not sure it can be taken off without spending many dozens of hours and even then, I'm not sure it can be done without ruining the paint or causing other cosmetic damage. There was relatively little that I took off myself. I'm curious what people might think would be the amount of depreciation caused by the tar if I were to try to sell.
The car is an '86 Targa. A good driver (engine and transmission never apart). Cosmetically good but not awesome. Hood could use a repaint.
Opinions would be appreciated.
1986 Guard's Red 911 Targa
Old 10-15-2007, 07:53 AM
emac's Avatar
Please don't laugh, but I would use and or try WD 40. I had some tar on my car albeit not to the extent of yours. I was amazed. Did NO harm to the paint.
Ernie 81 SC
Old 10-15-2007, 08:13 AM
Wildman Emeritus
I had a similar situation with my Kawi and ended up using Coleman fuel which worked very well. Just don't smoke.
Mike Andrew
1980 SCWDP
2017 SubyForester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-15-2007, 09:01 AM
kerosene is the main ingredient in "bug and tar remover".
206 637 4071
Old 10-15-2007, 09:03 AM
Nine9six's Avatar
What John said.
As a follow on to that thought...
An old timer once told me that one of the best applications to make the paint look its best, was to mix up some kerosene and water (1:3 ratio) and apply liberally for a clean and shine second to none.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-15-2007, 09:10 AM
Senior Member
Early_S_Man's Avatar
Porsche Crest
3M used to make a low-volatility product called 'Paint Cleaner' that is now called 3Mô General Purpose Adhesive Cleaner, 08984, 1 Quart . A bit soaked into a folded paper towel does not evaporate in five minutes or more, and it does exhibit an 'oily' nature similar to kerosene. One can lasts for years if only used once in a while in a multi-car household!
Another benefit of using 3Mô General Purpose Adhesive Cleaner, 08984, 1 Quart is that it removes silicones so that filler/primer/surfacer can be used on damaged areas.
ps,
A NIOSH-approved respirator rated for organic solvents should be used, and the MSDS sheet should be read:
http://solutions.3m.com/wps/portal/3M/en_US/3MAutomotive/Aftermarket/Products/Product-Catalog/?PC_7_0_53BC_nid=GSSPN37QHGgs6DTWTJQPBBglGSJMCM61B Gbl
http://multimedia.3m.com/mws/mediawebserver?66666UtN&ZUxL99XlXT_5XMXnVu9KcuZgVU_LXT1u666666--
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-15-2007, 09:56 AM
I know guys who work with asphalt clean their rakes with diesel, might be worth a shot but your car may also stink for a long time...I would try it last.
Old 10-15-2007, 10:20 AM
King Broinyo
Nostril Cheese's Avatar
diesel fuel and a rag. wash and wax afterwards
Old 10-15-2007, 10:21 AM
Slumlord
Porsche_monkey's Avatar
Or varsol. Or gasoline.
Old 10-15-2007, 11:15 AM
kilodawg's Avatar
Be careful....this looks like a Guards Red car in which case you don't have clear coat but on clear coated cars the clear frequently didn't cover the basecoat well in these areas and any aggressive solvent can easily remove the paint. Just be careful and check first.
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 10-15-2007, 11:25 AM
Googone
Old 10-15-2007, 11:51 AM
Yep. Goo Gone
Old 10-15-2007, 12:29 PM
911 addict
mtbguy's Avatar
Goo gone +3 , but might be more expensive than some of the other ideas.
1987 Carrera Cab
Toyota Landcruiser
500SL
Old 10-15-2007, 12:38 PM
Wow! Thanks for all the suggestions. My main concern is causing paint damage but maybe I don't have to worry as much as I thought. I expect this will take many hours....
Jon
Old 10-15-2007, 02:17 PM
Sultan of Sawzall
rouxroux's Avatar
WD40...if that scares you, use Griot's Garage Oil & Grease Remover spray (microbial action like the oil slick-eating product) It will appear to just "melt away", then rinse.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 10-15-2007, 04:09 PM
theclaw's Avatar
WD40. I give my Ducati's a bath in it every fall. It it also a great water repellent but I've heard Tri-Flo works better as a water repellent.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 10-15-2007, 05:48 PM
Newbie
PorchFile's Avatar
tar removal
Contact your County Risk Management Office - they should cover it.
Take it to a professional shop.
We had the same problem recently in my county - they ended up detailing about 50 cars.
Speed is a function of money....how fast do you want to go?
Old 10-15-2007, 08:55 PM
Norm Faustino's Avatar
Olive oil will destroy tar and won't harm paint in any way.
78 911 SC "Scratchy"
2004 Mini Cooper S "Pele" (gone but not forgotten)
1979 classic mini clubman-"Coolio"
Old 10-15-2007, 09:25 PM
I've already contacted them and am in the process of submitting the information. I expect I'm not the only person this has happened to and hopefully they'll take care of it without me having to take it any further.
Thanks!
Jon
Old 10-16-2007, 07:28 AM
Bland
RWebb's Avatar
That's good - but they - or whomever they contract with - may not be as careful with your car as you would be.
Use the mildest thing first. And that would be olive oil -- or a cheaper salad oil like Wesson or something. Then step up with Goo Gone or the 3M stuff or one of the creamy versions of bug & tar remover (which may rely on something milder than kerosene).
I wouldn't worry too much about stuff up under the fender well (your pic) - it is going to be sandblasted by rocks and grit anyway.
Maybe do the top surface paint & let the County do the fenderwells...
Long Term Maintenance:
http://forums.pelicanparts.com/porsche-911-technical-forum/189572-long-term-commonly-neglected-maintenance.html
Old 10-16-2007, 01:30 PM
