-   -   Going to replace clutch cable do I need this too? (http://forums.pelicanparts.com/porsche-911-technical-forum/372610-going-replace-clutch-cable-do-i-need-too.html)
oregonmon 10-17-2007 10:20 AM
My clutch squeaks (not that big of a deal) and is pretty stiff it probably is time to change the clutch cable right? It's a 79 SC and I'm sure the original.
Reading a couple posts guys were saying it made a lot of differrence and I'd hate to get stranded when it goes POP!
Do I need to replace the $35 clutch spring? Is this what people call the helper spring? I see it listed for the Turbo, same for the SC?
DaddyGlenn 10-17-2007 10:34 AM
The clutch helper spring is pretty easy to replace...unless you've got some rust holding it to the pin like I did (PITA). I'd change the bushings, too. You might want to look at your pedal assembly while your at it. No personal experience, but I understand the pedal bushings wear out and can cause issues.
oregonmon 10-17-2007 10:39 AM
Is it just the one bushing? Either bronze or plastic?
oregonmon 10-17-2007 12:44 PM
I see that the spring is unavailable, kinda unsure if I need to replace. Any thoughts, would like to order these parts today.
jtfreels 10-17-2007 02:15 PM
I would also recommend rebuilding the pedal cluster. I used the wevo bronze set, cause that is what the PO had bought and never put in.
Regarding the omega spring, I would check the bearings around the pin, mine were obviously crushed with pieces missing.
Rodsrsr 10-17-2007 03:54 PM
+ one on rebuilding the pedal assembly. Its very common for the roll pin down at the pedal to shear off, dropping your clutch pedal to the floor. The big spring at the pedal is pretty robust, so it should be ok. The omegas get a little worn. New cable, rebuild pedal assembly with bronze bushings, and new omega, and you should have no problems.
Moke81 10-17-2007 04:15 PM
Read the tech article from our host on clutch cable install. I also recommend the 101 projects book. The most difficult part was getting the helper spring off. I used my dremmel and cut it off.
_____________
1981 SC Coupe
