Last Engine Oil Drop There Were Small Bits (about 3 To 4 Millimetres) Of Green Rubber In The Crank Case, Have Since Dismantled Motor And All Seals Are Intact Although Have Found More In Oil Ways Anyone Ever Had The Same Thing Happen????? How Do You Test An Oil Pump Is Working Correctly???
Do you have any pictures?
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Friend of Warren
Green rubber is probably a o-ring. Can't imagine how one could just break apart.
Kurt V No more Porsches, but a revolving number of motorcycles. |
no i dont have pictures but it is the same as a pump or oil cooler seal and it looks like it has been munched up by the oil pump. I would have thought if this was the case it would have been caught in the filter in the oil tank.
