sc wont rev above 4k
Hi folks
My sc will tick over fine, it will build revs up to 3.5 k anything afrter this and it splutters and backfires like mad and wont go above 4k, I have an msd 6al in place of the cdi rotor and cap are ko plug leads are fine. Any ideas? please please I really wouldlike to have the car running at least once this year.
Thank you
Gordon
Old 10-08-2007, 05:33 AM
Trotskyite
I just had the same issue with mine. The injectors were leaking, and the oxygen sensor wasn't working properly. Runs like a top now! Good luck, when I was looking on these forums for help there are a long list of possibles, seems like it can be one of ten things causing your problem.
Old 10-08-2007, 06:45 AM
Scott R's Avatar
Do you still have a catalytic converter? Or did you ever have one? It could be clogged up.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-08-2007, 06:50 AM
just the ten things? thats not too bad then
never had a cat uk car 1981
ssi exchangers
Hell Belcho
Nostril Cheese's Avatar
Originally Posted by gordoncoll View Post
Hi folks
Thank you
Gordon
You said it has an MSD. Do you have the tach adapter? On my old SC, I installed the tach adapter and had the exact same thing happen, sputtering, wont rev over 4K, etc... I disconnected the adapter, and she ran fine. The odd thing was that the tach worked fine without the adapter as well...
Old 10-08-2007, 08:19 AM
didnt need to use the tach adapter as the tach worked fine without it.
the backfires are inlet backfires not exhaust ones by the way.
Old 10-08-2007, 08:22 AM
Smart quod bastardus
fredmeister's Avatar
Check to see that the wires are in the correct order on the cap, sounds like you have some wires in the wrong order. Next check the timing advance itself, it may be out of time, too far advanced or retarded.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-08-2007, 08:24 AM
Alii&Maui
Jesset100's Avatar
Did you install the correct rev limiter pill? I think it comes with the 3000 or 4000rpm pill installed from the factory.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 10-08-2007, 08:25 AM
Designer King
Paulporsche's Avatar
Have you checked your control pressures and mixture? Maybe your WUR is off and you are too lean, especially once warmed up.
Check the distrib. As someone said, is it advancing OK? If you turn the shaft @ the rotor, does it spring back?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-08-2007, 08:33 AM
the wires I know are on right, I cant get the car to time properly, the timing light is very imtermittent at 900 rpm on and off and on and off. I am going to put a cdi on it tommorow and see if I can time it using a cdi then go back to the msd, I am positive the wiring is correct. I will then look at the fuel metering heads and so on and so on.
I have put the correct pill in it.
Early_S_Man's Avatar
Porsche Crest
Gordon,
Your MSD box is having the 'classic' switchover-to-single-spark-mode' failure ... which occurs at 3000 - 3500 rpm.
Evidently, the high-rpm, single pulse mode fails first, followed later by the startup and low-rpm mode. Sounds like your low-rpm mode is dying fast.
All of the above info has been derived from postings on this board, as I don't do MSD, and haven't [won't, up til now] observed one in person while failing.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-08-2007, 09:22 AM
"Your MSD box is having the 'classic' failure ... which occurs at 3000 - 3500 rpm.
All of the above info has been derived from postings on this board, as I don't do MSD, and haven't [won't, up til now] observed one in person while failing."
where do i find out more about this??????
Old 10-08-2007, 09:29 AM
Somatic Negative Optimist
Gunter's Avatar
Gordon:
The distributor often gets neglected.
If you haven't serviced the distributor, go here for an easy clean/lube:
Distributor service (Clean and lube) real easy without removing the pinion gear!
I assume you know that the SC-distributor rotates counter clockwise (CCW) with the corresponding wire arrangement.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-08-2007, 10:05 AM
distributor is fine, followed that thread quite recently. this just came on suddenly one day when driving, one min fine next dead. got it started by retarding the dizzy and limped home.
now it will start and run up to 3.5 4k then all hell breaks loose and it cracks and bangs like fury
Gordon
Old 10-08-2007, 10:20 AM
I assume you know that the SC-distributor rotates counter clockwise (CCW) with the corresponding wire arrangement.[/QUOTE]
funnily enough this is wrong in my Bentley book !! I do know it goes couter clock but I thnk thebentley describes it as clock, weird
Old 10-08-2007, 10:21 AM
911mot's Avatar
Probably not the issue here but, if you leave the 3mm allen key in the C/O adjustment slot, it wont rev past 4k.
BTDT
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 10-08-2007, 10:40 AM
I think MSD problem too...
Help here, maybe? Go to support.
http://www.msdignition.com/
Old 10-08-2007, 10:51 AM
tommorow I will be rewiring the msd after checking the car with a CDI, new leads rotor and cap going on tommorow, will also regap the plugs and clean them.
report back later how it has gone !
Old 10-08-2007, 12:40 PM
cracked air box or or intake rubber sleeve ripped
Old 10-15-2007, 08:11 PM
dtw dtw is offline
GAFB
So, did you ever send Anna her parts or give her money back to her???
Several BMWs
Old 10-16-2007, 07:22 AM
