mca mca is offline
mca's Avatar
Does Top of My Engine Look Okay?
Trying to chase a temp problem on my SC. I pulled my fan housing to get a better look at the cylinders. Since I have nothing to compare my engine to, I am hoping that some of you will let me know if everything looks 'normal'.
The right side towards the rear seems rather oily to me. I was pretty hard to get a good photo - but I think that these get deep enough.
Thanks in advance!
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-17-2007, 12:37 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
Is the engine still inside your car? It seems like it is. The engine looks fine to me, nothing that I would think is causing a temperature problem.
Have you tried to run the engine and felt the oil supply and return lines to your thermostat (to see if the oil is making it to your tombrone cooler in the right front wheel well)?
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 10-17-2007, 12:50 PM
mca mca is offline
mca's Avatar
-Matt
Yes, still inside car.
I don't want to get into all of the 'other' issues that might be causing high temps b/c I already have open threads regarding that. My main concern now is simply ruling out dirty cylinder heads.
But to answer your question, ... all of my lines get hot, i have great oil pressure, timing and mixture are good, car runs great. The only thing that has changed since last summer was that I removed my heater blower/components and added a block off plate. Had it at the track in March and it almost reached 250 ... currently it can reach 250 just by driving on the highway for 30 mins.
Old 10-17-2007, 12:58 PM
[QUOTE=mca;3536852
QUOTE]
Isn't that the right side toward the FRONT?
Common area for leaks - oil cooler gasket, etc. Wouldn't cause overheating.
Old 10-17-2007, 01:10 PM
mca mca is offline
mca's Avatar
Yes ... right side towards front of car ... I was referencing the photo instead of the car.
Seems like I can rule this out as a culprit then.
Old 10-17-2007, 01:16 PM
You are missing your fan that's why it's running hot!
It wouldn't hurt to clean off the oil residue but I wouldn't expect your car to be reaching 250 on the highway over that.
Can you post the links to the other threads you have going on? I don't want to ask questions that you have already answered on the other threads.
mca mca is offline
mca's Avatar
Meat Thermometer - Oil Filler Neck - Accurate Temps?
I was following this one too:
SC Still running HOT UGH!!! What could be wrong?
Old 10-17-2007, 01:19 PM
j_mancini's Avatar
Could be worse. It could look like this!
John
1982 911SC Targa ~ Gulf Blue (gone but not forgotten)
Old 10-17-2007, 02:54 PM
Hi MCA. Are the air guides present on the bottom of the cylinders?
Old 10-17-2007, 03:11 PM
Mancini, expliquez. What is that in your photo?
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 10-17-2007, 03:29 PM
Assuming no issues with the engine or oil system and warmish ambient temperatures, a fender or front-mount oil cooler is the solution to 250º oil temps. If fender-mounted, in addition to an electric fan, provide good air flow with air diverters and/or ducts.
Sherwood
Old 10-17-2007, 03:41 PM
BlueSideUp's Avatar
Send a message via AIM to BlueSideUp
My engine looked similar to mancini's photo. The breather cover and thermostat were leaking for quite a few years and ended up making a serious mess.
-Jess
Old 10-17-2007, 03:43 PM
mca mca is offline
mca's Avatar
Wow, that is some serious stuff. Were temps higher as a result?
Old 10-17-2007, 04:27 PM
mca mca is offline
mca's Avatar
Keith ... not sure I follow. Can you explain?
You are not referring to the air flow guide behind the fan housing are you?
Old 10-17-2007, 04:32 PM
AutoBahned
RWebb's Avatar
black sheet metal pieces
Old 10-17-2007, 04:40 PM
mca mca is offline
mca's Avatar
The pieces that run above the bottom valve cover gaskets?
If so, yes.
Old 10-17-2007, 06:15 PM
I can empathize with your frustration, mca. Have you had a look at your spark plugs? This may help to give you an indication of a lean condition. I would also check the flow of each injector. Improper fuel at one or more cylinders would mean detonation and high temps. Any signs of an exhaust leak at heads due to corrosion on the heat exchangers?
Old 10-17-2007, 06:17 PM
chrisp's Avatar
if you are running the stock trombone cooler stop looking. It's right there in front of you - the trombone. It sucks! A Carrera fender cooler will drop you 20-30 degrees and a front mounted cooler will go another 20-30 depending on the style. My SC ran 250 degrees in stock form. It now runs 190-200 on the hottest of track days. I have a front mounted cooler.
'83 SC
Old 10-17-2007, 06:28 PM
chrisp's Avatar
and by the way my car is chiffon as well so you can't use that as an excuse either
'83 SC
Old 10-17-2007, 06:31 PM
mca, I've been following both threads and I'm thinking that you might want to remove the external thermostat and test it. You might have an external stat that is not completely opening. It would restrict flow to the t'bone cooler. It wouldn't effect oil pressures but it would limit the cooling properties of the cooler. Someone may know the answer to this..but I'm wondering it you could run without the thermostat for testing purposes? Don't do that until one of the big guns weighs in.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 10-17-2007, 06:43 PM
