Danny_Ocean's Avatar
Old 10-15-2007, 09:14 PM
ttt
Old 10-20-2007, 10:41 PM
Jeff Alton's Avatar
Plug it in and move the float up and down and see if the needle on the gauge moves.
Cheers
www.turn3autosport.com
Old 10-21-2007, 09:10 AM
i used the up-graded rubber gasket instead of cork for the install. It'll throw off the reading slightly.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-21-2007, 09:35 AM
DUK DUK is offline
DUK's Avatar
I used an ohm meter between"G" and ground. I saw the resistance go up and down by turning the sender up and down.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 10-21-2007, 09:54 AM
Cheers
How do you get to the float...it is sealed inside the aluminum tube?
Old 10-21-2007, 11:19 AM
Evolved
Mo_Gearhead's Avatar
Check resistance as mentioned above.
No need to 'get to the float'. Rock/rotate the tube. The float should move inside the tube and you will see the results. If it's (float) stuck ...you have additional problems.
Don't fear the reaper.
Old 10-21-2007, 01:11 PM
