ttt
Plug it in and move the float up and down and see if the needle on the gauge moves.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
i used the up-graded rubber gasket instead of cork for the install. It'll throw off the reading slightly.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I used an ohm meter between"G" and ground. I saw the resistance go up and down by turning the sender up and down.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Evolved
Check resistance as mentioned above.
No need to 'get to the float'. Rock/rotate the tube. The float should move inside the tube and you will see the results. If it's (float) stuck ...you have additional problems.
Don't fear the reaper. |
