-   -   Electromotive TEC I Programming (http://forums.pelicanparts.com/porsche-911-technical-forum/373188-electromotive-tec-i-programming.html)
dad911 10-20-2007 05:37 PM
I have a 2.7 with Electromotive Tec I (DOS based)...
PO gave me a floppy with a few configuration files on it. Is there any way to tell which is currently loaded?
TimT 10-20-2007 07:30 PM
Tec 1 is quite primitive..... but there are bunches of cars running it and they run well..
Its been years since I played with a Tec 1 , but from what I recall, you cant save the bin file from the Tec, you can modify and reload the bin file (make changes>>key off>> key on>>up load> etc)
Is the engine running now? if so how does it run?
If its running well I take that floppy and toss it
dad911 10-20-2007 07:43 PM
Thanks Tim. I bought the car this spring. It runs well, but I wanted to check the programming.
