Newbie observation question...
My 3.0 motor does not have this! What is it? I know the other thing is A/C....
http://i167.photobucket.com/albums/u...ilms74/300.jpg |
That is an air pump, you don't want one.
What is a signature edition Carrera 3.0? Tell me more... |
Is it any big deal to dispense with it? Any down side?
Only down side is passing emission check, if your state requires it. It's part of the system that will fail you on the visual if it's not there
Aside from the air pump, I'd check with this group and see if it's possible to remove that 5 blade fan and replace it with an 11 blade fan. Better cooling, especially during those long hot Texas days.
One delightful aspect of dwelling in a rural state is not only no emissions check, a few years ago they cancelled their safety stickers.
I would like to remove mine, but am reticent to do so as it is running SOOOO well now. Surely you don't simply "unhook"?? |
No you shouldn't just unhook it. If removed, the engine needs to be tuned differently, and maybe different spark plugs would be used.
I'll wait till it goes belly-up.
Thanx |
I would do a search for further opinion on plugs and lose that thing, your car will thank you for it, it makes lots of jobs much easier and the engine bay looks better without it. Then move on to the heat backdate ;) |
Ripped mine out and plugged up the holes... no sweat no worries...
-michael |
""Then move on to the heat backdate ""
uhhhhhhh..wanna touch a bit on that? |
Andi,
I am in Houston as well. I am sure you know your car is exempt from TX emission testing so you won't need the smog pump. I removed it from my old 78SC, but taking out the plumbing "spider" under the car was not easy. There are special plugs from Weltmeister that close the injector holes. Just starting on my 70T project car. Ulrich |
Thanx for the info...gone to git smart.
I want my pump off too. i do not have A/C, so removal of the pump will make the left side of the motor a heck of a lot easier to work on. now i have to research how to 'plug the holes'..
| All times are GMT -8. The time now is 05:37 AM. |
