-   -   Missed Shift - When do you worry? (http://forums.pelicanparts.com/porsche-911-technical-forum/373475-missed-shift-when-do-you-worry.html)
jcsjcs 10-22-2007 02:02 PM
I had a blast over the weekend exploring the back roads of Eastern PA. '84 911 Targa - with the top off. The leaves are just changing, the roads were dry and curvy, and this was my first time with the car outside of New York City!
I did have one "Missed Shift" from 5th to 2nd - ugh. Looked like the tach went to about 7000 (that is just an after-image in my head for some reason - not necessarily true.) I reacted very quickly and punched the clutch and found the right gear. No obvious after effects - the car performed fine the rest of the weekend.
Should I worry?
Oh Haha 10-22-2007 02:08 PM
You should be OK. 7000 isn't really that high for these engines. If you don't hear any funny noises don't worry about it. If you spun it up to 8000 I would worry but you should have an RPM limiter so you don't do this.
Brent Lineker 10-22-2007 02:13 PM
The rev limiter will not help you if you blow a shift,it only cuts spark but does not stop your engine from over revs any way mechanically.
Oh Haha 10-22-2007 02:16 PM
Brent,
Yup but I was thinking that he might feel he had free reign to run it up to 8000. Guess I wasn;t looking at what I was typing. duh.
Jeff 10-22-2007 02:31 PM
Does it idle OK?
jcsjcs 10-22-2007 04:05 PM
Idle is the same as always (at least since I have had the car - about 1 month.) Stays stable within about 50 RPM or so.
What's the solution to this problem (other than being more careful)? Shifting from 5th to 4th feels like a bit of a potshot - too far to the right and you get some reverse gear grind, too far left and you blow your engine.
Does a Gate Shifter solve this problem?
spartan 10-22-2007 04:08 PM
get a wevo shifter
Jeff 10-22-2007 04:21 PM
Sounds like you dodged a bullet.
Wevo is a great shifter. You can also look at Rennshift. They both have centering springs (will put the shifter in between 3-4 in the neutral gate) which should alleviate hunting for the correct gear.
emac 10-22-2007 04:24 PM
Got lucky-- I did the same thing and had to replace the clutch. Needed it anyway.
dad911 10-22-2007 05:25 PM
if the shifting is vague, inspect/change the bushings.
$6500 If you bend the valves..... there, bet you shift a little slower now......;)
tcar 10-23-2007 09:45 AM
RPM limiter won't help a bit with a missed shift.
Wayne 962 10-23-2007 09:52 AM
Run a compression check - it will tell you right away if you have a problem...
-Wayne
304065 10-23-2007 10:15 AM
Run a compression AND leakdown test and report the findings.
It is far better to tear down the engine to replace the rod bolts and any bent valves than to break a rod and blow a window you can put your fist through in the side of the engine case.
jcsjcs 10-24-2007 07:06 AM
How difficult to run compression and leak down at home? What do I need to do it myself?
While I am concerned about the missed shift - I have absolutely no symptoms that anything is wrong or different - no strange noises at idle, normal idle, car is running as always, etc. I expect that the blip in the 7k range did not do any damage but are there any other things I should look out for to see if any damage was done? While I agree I don't want to "blow a window in my engine", I also don't want to overreact with nothing to go on other than the story itself, i.e. no symptoms of a problem.
Thanks for the input!
304065 10-24-2007 07:54 AM
You need a decent air compressor and a leakdown tester. A special adapter for 911 engines that fits into the spark plug hole with a quick-disconnect fitting is nice to have.
Or any local shop can help, it's about a 1 hour task to do it right. Where are you in the City, I can recommend somebody to take it to if you don't want to invest in the equipment.
jcsjcs 10-24-2007 08:03 AM
I live in Brooklyn, but have no problem traveling to Long Island or the other boroughs.
Eagledriver 10-24-2007 05:14 PM
You can tell alot just by turning over the engine by hand. Turn it with a wrench on the fan nut while pushing on the side of the fan belt to keep it from slipping. You should have the same compression feel on all 6 cylinders. If you feel some of them are significantly easier to turn through TDC then you may need to investigate with a leak down test. You can also hear the air hissing out when you do this. It should sound the same on all 6 cylinders and should come from the case of the engine not the intake or exhaust.
-Andy
Wayne 962 10-24-2007 05:20 PM
Just run the compression check - for bent valve damage, it will tell you the same information as a leakdown. Running both is not really necessary...
-Wayne
