-   -   Strange Tapping sound when engine is HOT (http://forums.pelicanparts.com/porsche-911-technical-forum/373897-strange-tapping-sound-when-engine-hot.html)
matty74 10-24-2007 06:01 PM
I recently had my 3.0 SC motor rebuilt top and bottom, heads and CIS overhauled. I installed a 3.2 oil pump and oil redirection.
I drove it nice and easy during run in and and it runs beautifully and pulls hard.
Now when I sit in traffic and it gets above 180 C it starts to produce a noticable tapping sound at idle and not in gear. I have removed the fanbelt it's not the alt bearing and it sounds like its comming from the lower pully although I can't be sure.
It only does it when it gets really hot, when under power it does not make the sound.
I have all the rod bolts and and internals machined new big and smallend bearings pots redone and new rings etc.. The tapets and cams were re-used.
new chains and rails, re-used oil fed chain tensioners.
Is the 78SC just a noisy motor or is there somthing that was missied.
Matt
BURN-BROS 10-24-2007 06:21 PM
Common noise on the SC, raise your idle a bit.
matty74 10-24-2007 08:31 PM
It already idles at 1100 rpm I think the CIS is running a bit rich
BURN-BROS 10-24-2007 08:49 PM
Then reduce the idle. It is most likely intermediate gear backlash that presents a condition at a certain rpm.
