Chain Tensioners?
Without open the timing covers, does it look like I have some sort of hydraulic chain tensioners? Do the oil lines allude to that?
Thanks in advance. I am trying to get a handle on what I bought, so sorry for all the questions. I still have no idea what the switch under the ignition is, thinking it is for the sunroof, but have not had the ba**s to try it!
2007 997 TT 1992 500e |
Yup, you have the Carrera oil-fed tensioners installed.
Babak |
cool, thx for the response.
Send a photo of the switch as, typically, the sunroof switch is above and a little to the left of the ignition just--under and between the oil temp/press gauge and the fuel/oil level gauges. I'm sure the switch you have will be recognized by someone as soon as it's posted.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 10-24-2007 at 05:50 PM.. |
That switch is for the side view mirrors - driver and passenger side, depending on which direction the switch is toggled.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
