Send a message via AIM to bfairless Send a message via Yahoo to bfairless
Valve adjustment
How often should i do a valve adjustment. I was going to change the oil and tranny fluid today and thought about checking the valves as well. The manuals kinda contradict themselves when talking about doing these things together. On one hand they want you to change the oil and tranny fluid while the engine is warm because you will get more oil out of the car and more metal in the oil for the oil change and the tranny fluid change. On the other hand you should adjust your valves when the engine is could, preferably left over night. How do you do them both?
Also, if I cant find swepco tranny oil could someone recommend another? is there a generic gear oil weight i should be looking for at the local NAPA or PEP boys?
84 911 Carrera
Old 10-28-2007, 08:22 AM
Somatic Negative Optimist
Gunter's Avatar
JW uses 80/90 GL5 in the 915.
If it's good enough for him, it's good enough for me.
Make sure it says GL5.
Before you drain, make sure you can open the plug to re-fill the transmission.
Here is what I do:
Engine hot, drain oil, leave it draining overnight.
Next day, adjust valves.
For the transmission, it's thicker, so, leave it draining all night.
For re-fill, I use a cheap suction type hand pump with a short piece of tubing to fit into the hole, works good.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-28-2007, 10:53 AM
jbrand540's Avatar
To refill the tranny I always get the cheap hand pump that screwes into the oil bottle. Little hard on the wrist but it is pretty easy to work with from under the car and cost about $5 so you can throw it away when your done.
'89 Carrera Cabrio
'01 Audi A6 2.7t
'01 BMW 540i
'06 Dodge Ram 2500 Diesel
Old 10-28-2007, 10:57 AM
