Moses's Avatar
$129 Tire storage solution.
Just picked this up from Tire Rack. http://www.tirerack.com/accessories/ttr/tire_storage_rack.jsp
It's high enough so no one will bump their head on it. Wheels are now completely out of the way. The build quality is far nicer than I expected. Installation is really easy; I'd give it a "two bloody knuckles" rating.
My rating system works like this:
1) One bloody knuckle; Filling gas tank, plugging in small appliances.
2) Two bloody knuckles; Changing tires, mowing a lawn, fixing a faucet.
3) Bloody hands requiring bandages; ANY engine or transmission work.
4) What the hell was I thinking?; Roofing, any activity that takes place in the dark crawl spaces under the house. ANY type of electrical work. Work in this category generally ends up with a visit to the emergency room.
Old 11-03-2007, 02:55 PM
Jandrews's Avatar
Nice. That thing looks like it has adjustable width. That's a handy feature for those of us with wide wheels/tires. Assume you located studs and mounted it that way? I definitely see one of those in my future. No more tripping over tires or having dirt accumulated under around a stack of unused wheels. Thanks for the tip and the injury-meter!
JA
John
- '70/73 RS Spec Coupe (Sold)
- '04 GT3 (Sold)
Old 11-03-2007, 03:41 PM
Zeke's Avatar
Looks great, but I think you need a safety for when the shaker comes. All four of those on the front of your car will not be pretty.
Old 11-03-2007, 03:42 PM
Virginia Rocks!
VaSteve's Avatar
Nice. A friend built something similar. But he's OCD, so he went into the crawlspace and tied it into the house structure. I naturally assumed that's what was required, so I haven't built my own, but I could sure use the space. Looks like I need to check this out!
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 11-03-2007, 03:53 PM
Moses's Avatar
JA
It's adjustable width and the hanging bracket comes pre-drilled for 16" on center studs. It's hung with 6X 3" lag bolts directly into studs. For earthquake safety I'll cable the wheels to the rack. I don't think the rack's coming down unless the house does.
Old 11-03-2007, 04:58 PM
AutoBahned
RWebb's Avatar
save $105 and just use 2x4's...
Old 11-04-2007, 11:58 AM
Designer King
Paulporsche's Avatar
What is your garage floor and baseboard material and finish? Also, where are you located?
I see you are "out there" but I'm assuming you are not wandering in a middle eastern desert, despite your name.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-04-2007, 12:35 PM
Moses's Avatar
I'm in northern California. The floor is concrete with epoxy paint. No baseboard, just a 3" concrete lip all around.
Old 11-04-2007, 04:55 PM
jhubs's Avatar
Thanks Moses! I've been tripping over my 6 and 7 Fuchs since I put on the 7.5 and 9 Rota Foxes. This item just went on the 'ole Xmas list!
Jerry
1995 993 Carrera, Guards Red Coupe (current)
1987 911 Carrera, Marine Blau Metallic (06-08) Gone but...
1965 Yellow Mustang Convertible (65-05)
__________________________________________
It is always a good idea to keep the pointy end going forward as much as possible.
Old 11-04-2007, 06:20 PM
NASA instructor
bornrich's Avatar
This is what I got for my garage:
http://www.pitposse.com/folduptirerack.html
Really secure. Only draw back was poor assembly directions. Figured it out and got it all install in under an hour.
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 11-05-2007, 04:29 PM
Don Plumley's Avatar
Your garage is too clean!
Don Plumley
M235i
Old 11-05-2007, 04:49 PM
