-   -   first engine drop - clutch prob (http://forums.pelicanparts.com/porsche-911-technical-forum/374457-first-engine-drop-clutch-prob.html)
dede911 10-28-2007 10:00 AM
Hi all,
Thanks for guiding me trough my first 911 engine drop.
It took me 3 hours completely on my own...here is the pic
http://forums.pelicanparts.com/uploa...1193590340.jpg
The reason for this engine drop is my "sticking clutch " problem: engine and tranny cold, the clutch don't gets disengaged. After 50 m driving everything is OK.
This is what I found after dismantling the clutch components:
http://forums.pelicanparts.com/uploa...1193590613.jpg
http://forums.pelicanparts.com/uploa...1193590730.jpg
Rusty splines, wear on the TOB outside has touched the guide tube, wear on the inside...
What do you think?
Tx,
dede
Gunter 10-28-2007 11:28 AM
Complete new clutch components, I recommend the light-weight sports package.
New cable.
New guide tube and seals/O-ring in the transmission.
New seal for the input shaft.
Good time to change transmission oil.
New main seal (Engine)
If the flywheel needs a grind, consider making it lighter by machining portions out of it.
I think Henry Schmidt, or Steve Weiner, does it? A re-balance, of course!
RWebb 10-28-2007 11:29 AM
clean up the rust and examine the splines carefully - prob. ok. see if you can post a macro pic that is in focus (borrow a camera?; more light; tripod)
obviously it was w/o grease
-replace TO bearing and typical 'while you're in there' type components
- bush sand surface rust off of PP
- examine clutch disc for wear
- check flywheel surface
- maybe just replace the clutch cable anyway
best to have 2 adults to put motor back in
how is the clutch pedal actuation itself?
Zeke 10-28-2007 12:35 PM
Quite distance from Belgium. :D
Gunter 10-29-2007 08:31 AM
Yeah, nice country and I remember Spa and Porsche-racing.
Should have been more precise.
I mean H. Schmidt and S. Weiner could provide details on how to lighten the flywheel.
There was a post showing how sections of the flywheel were machined to reduce weight.
I'll do that next time the engine is out.
